Just make sure you don’t use recon mode on car!Thank You...
True, but OP said they had an MXS 5.0 so just pre warning them just in-case!If you have an MXS 7.0 it doesn’t charge above 14.7V so won’t damage any sensitive electronics on MB
That is where you are supposed to connect it!Can you charge the battery by connecting the Ctex mxs 5.0 battery charger to the Positive & Negative jump start points under the bonnet?
