David Arnott
gazbiker,
Hold on a minute, just before you go pulling you car apart!
The PSE pump does cycle on now and again, this is normal operation. It runs each time you lock / unlock the car, each time you open / close the boot and will cycle when you have the "massage" seats on (if you have them) or adjust the seat lumbar support.
The pump should be fairly quiet and only run for a couple of seconds, is that the case with your car?
