MartinVC
- May 31, 2023
- A250 AMG Line 2018
I have a relatively new ( late 2018) A class A250 petrol. It started to develop mis-fire problems recently, then engine management light on and car going into limp mode on occasion. Diagnostics indicated a valve problem in Cylinder 3. After extensive labour it can now be seen that the exhaust valve is cracked. THIS SHOULD NOT HAPPEN IN A CAR THIS OLD AND LOW MILEAGE (UNDER 60K MILES). To compound the issue, Mercedes are out of stock for replacement valves throughout the UK and Germany !!!!
This means I am without a car for who knows how long.
1. This type of breakage shouldn't happen .
2. Mercedes should be able to supply spares.
The specialist diagnostics place I took the car to suggested this was not an isolated occurrence with these engines so I wondered if anyone else out there had any similar experience ?
