Dash binnacle LCD
bembo449
gainsborough , lincolnshire
Ive found a supplier that can provide a new dash LCD for the 215 however they dont mention the possibility of milleage correction, does the 215 definitely need this or can it be done without ? I searched LCD replacement with not alot of joy
If you're replacing the LCD panel and not the circuit board then it's a simple swap with no adjustments required. If you change the PCB then it will need sorting afterwards.
bembo449
bembo449
Ok LK ive already had it apart a few weeks ago so i guess aslong as i get the right part no off the LCD it should be ok
bembo449
bembo449
The part number on my unit is one digit out from the closest on the list from this supplier, do you think it will work ok ?
A220547347 v A2205407447
Your guess is as good as mine.
If you check EPC does it say 'replaced by' ?
www.ckinsurance.co.uk
