Dash lighting
big chris
Hello,
Two questions I would appreciate help with;
The dash lights and all the controls have gone out! interior door and rear ok!
300 ce 24v coupe 1991......any ideas??
Secondly, and assuming I get the lights working as a whole, how can I remove and change the bulbs behind the roller temperature controls in the cabin and the air vent bulbs top of dash?
Thanks, Chris
Gavin450slc
Manchester
www.manchesterfetish.com
well mine's older but..
It could be your adjusting switch - is it still a switch you turn to raise the brightness on your dash I control lights?
If so, popping your clocks out (not normally as bad as you imagine) and giving the switch a squirt of wd40 and a good few turns may do it.
The easy option is of course to just give the switch loads of turns to break the crud off the connections inside.
(it worked a treat on my old 450.)
