Daylight/parking light serious problem!!!
Hripsi
Mercedes e220 cdi
My car is mercedes e class w212 facelift 2014 Europe.
Hello everyone i replace control module ballast and everything works without daylight. The daylight switch on sometimes and when i take to ignition it stop working and the computer makes a mistake “check front right parking light”. The ballast is get from another car. I coded to headlight with xentry online.
Еven after coding, daylight comes on and goes out after starting the engine.
Please help me.
The headlight has been removed recycled and tested all the lights and its functions work.I used xentry online and the errors that come out are : led exterior lighting right front has a malfunction. there is an open circuit.Low value of voltage at circuit.
The problem is in right headlight. I put balast and control module from the left headlight to the right headlight and the daylight also doesnt work properly. I put the right headlight on leftside and daylight also doesnt work. Boys that open the headlight tell me that there isn’t a problem with lights they have test them and every lights work but when i put in the car and the daylight work 5 sec and after that stop working.
please help me with some
