Dead gadges
300e
se Michigan
This afternoon after washing the car the gadges stoped working. The Oil ,Gas, and Tack do not work at all, but the speedometer and clock still work.There is a buzz from under the dash. If I turn on a turn signal the buzz stops but the gadges still don't work. I love the car but have to have the gadges work . Has anyone had this happen? Please let me know . Thanks
pascal
near Dublin
sl320/1999/3.2
Are you sure it's from under the dash, and not in the engine compartment (beside the fuses).
pascal
near Dublin
sl320/1999/3.2
Sounds like a sticking relay, or a faulty ignition switch. It an easy job to slide out the instrument console for further inspection.
300e
se Michigan
I found # 5 fuse had a crack. I had to take it out to see the flaw. I think it is time to replace all the old fuses. thanks for the help.
pascal
near Dublin
sl320/1999/3.2
Well I did mention the words 'fuse box':smile:
Second one today, see the wiper thread below.
Yes I would change all the fuses, and make sure that they are all making good contact. I had a 230 back before the 300ce before the SL.
One of the fuses cracked, and created an arc from one side to the other. Luck I got it on time. Could have burned my whole loom.
