Hi, I'm about to buy my first merc (e class 220 cdi) which is also my first diesel, and i'm a bit suprised at how loud the engine is. Is this normal, and is there anything i can do to reduce the rattle? My car is a 53 plate and done 60,000 miles.
Hi, I'm about to buy my first merc (e class 220 cdi) which is also my first diesel, and i'm a bit suprised at how loud the engine is. Is this normal, and is there anything i can do to reduce the rattle? My car is a 53 plate and done 60,000 miles.![]()
i just turn the radio up a bit.
Hi Chris,I don't own a diesel myself and I'm sure that the true diesel owners will soon pipe up, but I have driven a 320CDI.
From my experience the engine was quite niosy on initial startup, much the same as any diesel, but when warm it was difficult to tell that it was a diesel.
From the inside when driving I don't recall it being any noticeably noisier than my petrol car.
Just a few questions:
Is it the typical diesel rattle or something else?
Does the engine get quieter as it warms up?
Is the noise mostly at idle?
Is it noisier inside than you expected?
Is it speed related?
If you raise the bonnet does the noise appear to emenate from the front of the engine (you may need to use the old stick/screwdriver stethescope trick) or from the injector pump and lines?
