john lang
It's not a Merc, so I'm being a bit cheeky posting it here but....
> I've got a VW Passat 1993 with a 1.6 t/diesel engine. Since I changed the
> head gasket 25000 miles ago due to oil leaking from the gasket, it runs
> OK, albeit it seems to run a little hot with the gauge around the 95C
> mark. The heater works very hot so obviously the coolant is circulating
> around the heater circuit. It doesn't loose any coolant.
> However, in normal running, the thermostat doesn't seem to open and this
> bothers me a bit. The bottom of the radiator and bottom hose are cold
> (the thermostat is fitted in the water pump where the bottom hose fits
> onto the pump.)
> If I take off the header tank cap and let the car idle for long enough,
> eventually the thermostat opens and the rad/ bottom hose heats up. After
> a bit longer, the fan cuts in.
> I've fitted 2 new thermostats and they are definitely fitted correctly.
> Also a new sender unit for the temp gauge.
> So, is this normal ? Is it right that this engine is so efficient that it
> can stay cooled using just the heater and bypass circuit without needing
> the radiator except in a traffic jam ?
> Best wishes,
> John Lang
200E 16V + Passat diesel estate.
> onto the pump.)
> Best wishes,
> John Lang
