Had the diagnostic check done today. Result was 3 faulty injectors and 3 close to the limit. They recommend fitting all 6 so does anybody know a source for injectors. regards AA
Regarding you injectors, my advice would be to find your local Road Haulage Company and have a word with them,-- find out where they get their Truck's Injectors refurbished and take the car there, they will remove the Injectors and totally refurbish them and replace,-- much cheaper than buying and fitting new injectors.
Try your local Bosch diesel specialist. I had all six injectors refurbed 3 months ago at a cost of £115 per unit plus fitting. No problems since and car runs a treat. I would use an outfit that has experience the last thing you want is a shoddy job where the injector bolts are stripprd on removal or the injectors don't seal properly. All six nozzles were replaced although only two or three had gone, but I decided to replace all to head off future problems. The nozzles were very badly eroded on close inspection.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
