diesel leak??? help
A
amir_r1
i noticed a stain on the road where my ml270 was parked and at first thought it was oil........ after checking i realised it was diesel. the bottom of the engine was all moist with it.
iv had the car checked by a local garage where they have checked the top and bottom of engine but cannot see where it has come from.
they have even tried leaving it running on a ramp for 3-4 hours but still no sign of where the leak has come from.
this is not regular leak as the 2nd stain on road appeared about 4 weeks later.
please help as this is mind boggling!!!!
thanks........
Amir
Hello and welcome,, the most common is a leak on the injector rail at the rear,, but a leak could be from anywhere or from anyone of the fuel lines, including the return to tank.
Lift the cover off the engine, and take a look,, you could also buy a engine cleaner spray to wash the block down with,,it will help to see where it is coming from
A
amir_r1
thanks Malcolm i'l give it a go and get it checked.
Xtractorfan
S class
Check all the plastic pipe joints around the pumps front of the engine ..just above the poly V belt these can drip leak and are very hard to pick up . the fuel then runs down behind the pulleys..
A
amir_r1
thanks Xtractorfan........ im checking everything........
i'll keep u posted.
thanks, amir
Cole@MBS
www.mbssouthampton.co.uk
most common cause, if you find these are leaking order two new pipe clips, they will break when undoing them!
