my husbands mercedes c220 cdi 20002 coupe keeps leaking diesel he as replaced fuel pipes but still keeps leaking out from under the bonnet any answers please.he loves the car but not the niggly little faults
I have had situations in the past that the fuel pump on the front of the engine leaks sometimes, so may need to replace it. They are expensive to buy but I saw a cheap one on ebay.
Have you checked all your pipes?
Where about abouts is the leak, is it from the front, side or back of the engine?
all diesel pipes have been replaced,diesel leak seems to be when cold,when warmed up appears to stop.it appears to be coming from back of diesel pump on front of the engine?
Correct terminology is either the high or low pressure pump. The high pressure pump is reasonably large and would fit into your hand. The low pressure pump is about the size of a 20 cigarette pack. Hope this helps.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
