Parkgate
Ok, I've finished the brake lines, changed the brake fluid, bled the system twice (pressure bled) and everything is rock hard! Turn the engine on and the brakes seem to work great. I took it up and down the road a few times, slamming the anchors on, and everything is fine including the ABS, but if I hold the pedal down it slowly sinks!
I can't remember it doing that before (sinking) BUT i must admit I can't recall ever a) hitting the brakes hard enough to trigger the ABS or b) holding the pedal under pressure like that before.. I just normally put it in P if waiting instead of pressing the brake pedal down hard ..is it me or do I have a brake system problem?
I can't see any weeps, the lines have been bled twice and without the engine running its solid. I need to get the car MOT'ed tomorrow, so is this pedal creep normal in a merc diesel or will it fail? I've just been reading about 'diesel pedal creep' but seeing how I've done so much work on the brakes and lines I could do with some input in case I've missed something!!
