Digital temp display
redgate
Hello
I have a problem with the digital outside temperature display in my 1996 C class.
It only seems to work when the car gets wet e.g. when being washed or driving though puddles and even then it show the incorrect temperature it shows “-38” and stops displaying anything when the car is dry.:confused: The clock and everything else on the instrument panel work fine.
Any help would be appreciated.
Thank you
Me thinks that the sensor is faulty or at least the wiring to it. Take it off clean up the electrical contacts and try it again. If no go then order up a replacement.
johnsgti
Rochester kent
I have a similiar problem with my 1996 c class, have been looking for the sensor on mine believe it is in the front bumper somewere, is this true?
Thanks for any help.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Just fixed my outside temperature display, I can confirm that the sensor is behind the small part of the lower grill on the N/S.
Mine pushed into a forward facing hole within that grill.
Depending on the age of your car you may have to replace the entire sensor loom as the early chassis numbers the sensor was part of the wiring loom later ones it could be unplugged, this sensor will cost you less than a tenner.
Having looked at mine (unpluggable) 1 pin was corroded it may of worked if this pin was cleaned but it is very thin and very hard to get because of the way the sensor is constructed.
Have a look at the link below
http://www.detali.ru/cat/oem_mb2.as...242F441456&CT=F&cat=44V&SID=54&SGR=106&SGN=08
Hope this has been of some help,
Yes it is on the near side
