See elle Kay
- Jul 14, 2012
- Location
- Brittany France
- CLK 320 elegance 1999 V6
I have a 99 clk320 that has a gear shift problem.
How do I ensure to get the most amount of oil from the transmission? I removed the drain plug but only a litre or two drained out. I then removed the drain plug from the torque converter, which contained 2-3ltrs or so. I estimate a total of 5 1/2 ltrs drained out of the transmission in total.
Is there more oil somewhere? Should the gear lever be in a certain position? Have I missed something?.
i changed the transmission plug. The old one was quite soiled with oil.
id like to get the most oil out because the old oil is very dark brown/orange. Not confident that it had ever been changed. 180k km on the clock.
i wasn’t going to change the valve body plate, maybe I should.
some advice on how to get the rest of the oil out would be a great help. Thank you in advance.
mike
mike
