Haga750
Hello all, I've got a 1987 230e with 211k on the clock, and just keeps on going! However, like many others she wanders to the left and has uneven ride height at the front (about 25mm lower on drivers side). Are these 2 things related? as I understand from the forum you can get spring bushes to even things out.
The rear suspension has started creeking and squeeking like a good'un (not self leveling suspension) interestingly when the handbrake is on you can rock the car and it creeks'n'squeeks , handbrake released and no noise. But, the creek'n'squeek is still there when you hit the slightest of bumps ( both rear wheels ). Point to note when the rear is being lowered on the jack about half way down it makes that noise. Makes me think a component has to be under load to cause this problem.
Kind Regards Tony
Kind Regards Tony
