Does Tyre width reduction "badly" effect Speedo accuracy ?
TILTNTURN
CLK 200
Ok Front tyres on ,my E Class Coupe were 235/40/18. I had 2 new tyres , 225/40/18 .
Dropped car off at my local garage to have them fitted and he phoned me to say they were the wrong tyres and would give a pretty inaccurate speedo reading and therefore wasnt happy fitting them .
I asked him to go ahead and Id take responsibility if the boys in blue stopped me.
I appreciate the tyre ratio will be altered but being that speedos are already out by upto 10% then surely its not going to make that much diff >>>>> Or Is It?
Thanks in advance .
Tilt .
M80
Derbyshire
I compare to GPS speed,
but this would give an idea of speedo difference.
1.26% speedo difference. Hardly worth mentioning really.
Insurance 'may' have concern in the event. But if your manual details that size I wouldn't think they could say anything.
M80
Derbyshire
Yep, but the profile is a % of the diameter of the wheel.
I had to think about that.
And still got that wrong.
18" is the wheel diameter,
the profile here is 10mm less, so rolling diameter is less, by 1.26% apparently.
Have I got that right yet?
JBell
Torquey
C350 CDi Estate (GAD Edition)
Should keep to the same size tyres, not sure why you ordered the wrong size
AnthonyUK
Alton, Hants
C240 estate 2002
It's only 10mm (<1/2") but I wouldn't want to argue with my insurance company about it if I was involved in an accident.
Almost...
The 235 and 225 are tyre widths and the 40 is the aspect ratio or percentage of the width as a height
So 40% of 235 is 94mm and 40% of 225 is 90mm
It will under read on the speedo by ~1mph on the new sizes
Speedos are allowed to be out by 10% but only to over read - they're not allowed to under read - Mercedes are generally 2-3mph over so you'll be closer to accurate on the new sizes
Less comfortable though as less sidewall to absorb the road imperfections
TILTNTURN
TILTNTURN
CLK 200
Excuse me J BELL I didnt order the Wrong Size . I had 2 New tyres already sitting there and decided to have them fitted . Ask the question youll get the correct answer sir .
TILTNTURN
TILTNTURN
CLK 200
Thanks to all Barring Mr Bell .
Much appreciated .
Naraic
2005 CL500.
It may or may not be too detrimental for the speedo...but, BUT...you may find your crusie control knocks off at higher speeds because you have mismatched diameters at each end of the car.
Grumblepuss
S213 e220D 2017
also be aware that the difference in size will get worse with wear so it may only be 8mm to start with but then add full tyre wear onto that and you could have a another 12mm of difference so around 2CM height difference from a stock new tyres (based on most new tyres having over 7MM of tread and legal minimum being 1.6MM)
Almost...
Um.....
He'll be less accurate as the wheel will do more revolutions for a given distance so if it read high previously (which by law it must) it will be worse now.
brandwooddixon
Wolverhampton
S63 Coupe 2014
Isn't the speedometer reading taken from the gearbox drive to the driven wheels? So if only the front tyres are being changed then the speedometer will still read correctly.
The only issue may be, as stated in another post, that the cruise control may drop out or a fault flagged if the ABS sensors detect a large discrepancy in speed of rotation between the front and rear wheels.
Gazwould
C250 CDI
Almost...
But real world this doesn't happen , all theory.... , wheel weight is the ride quality definer .
GPS is King .
andys320
Sussex
Mercedes S211 280 CDi 2009, Porsche Boxster ,much missed Mercedes S320CDi 2003
Have to say this would be my understanding, happy to be corrected.
EmilysDad
Bury Lancs
ML350
I've no idea what my Merc or the Merc in question uses to determine speedo reading, but the Vauxhall Omega I used to have used the ABS sensor on one of the front wheels ....
Flyinspanner
Ruislip
Diameter should be the only thing that affects the accurcy of the speedo.
The aspect ratio is and width are the variables, the wheel diameter is a constant, but the other two affect the circumference, and thus the figure displayed on your Speedo for any given rotation…..
