Does WIS give diagnostic information for trouble codes?
atikovi
Suburban Washington DC
2007 S550
I just replaced the conductor plate in my W221 with a virginized used one, and I am getting:
  • 2725 The internal electrical check of component Y3/8y6 (B2 brake control solenoid valve VGS) has failed
That wasn't there before the plate was replace so I'm wondering if they send me a defective one.
ajlsl600
france
Have you re checked all Yr connections then noted and cleared that code? Does it come straight back? Where did you get the conductor plate?
A
atikovi
2007 S550
I swapped solenoids and the same code came back, so the Ebay seller is sending out a replacement conductor plate. Will see how it works.
ajlsl600
france
Think that's likely ur issue. Be very careful not to introduce another issue whilst doing that.
mioba
Nottingham and Köln
WIS is workshop manual - how to diagnose, repair, replace.
STAR (xentry is the diags) that will point to WIS.
Intertwined
JoeHorner
2003 W203 C270CDI Elegance
WIS doesn't have much diagnostic information, it's more procedures for removal / fitting.
Xentry / DAS (depending on the model) has step-by-step diagnostic routines - "test X, result should be Y. Is result ok? (Y/N)" and so on until it tells you to "replace Z".
They basically lead you through a logical diagnostic tree for that particular symptom / code which includes any other systems that might be affecting things - which might not be immediately obvious given the huge number of controllers involved.
You can also run quite a lot of those diagnostics in "simulation" mode without actually connecting to the car where they involve measurements like voltages or checking connectors which don't need a live connection.
www.ckinsurance.co.uk
