DOOR MEMORY SWITCH BUTTON 123
TONY PRESCOTT
MANCHESTER
CLK 09 30
I HAVE LOST THE BUTTON ON MY CLK WHICH ALLOWS YOU TO SAVE SEAT POSITIONS. ANY IDEAS PLEASE I DONT WANT TO REPLACE THE WHOLE UNIT
whitenemesis
CLS55 AMG '05
Welcome!
How did you loose the button?
p.s. DON'T SHOUT!! :)
T
TONY PRESCOTT
MANCHESTER
CLK 09 30
does your clk have the button im talking about and if so does it just pull off?
Miffy
Bromley, London
CLK 320 CAB Elegance C208
my panel will be different to yours, mine is a 208, yours is a 209
brandwooddixon
Wolverhampton
S63 Coupe 2014
So did the button fall off? Do you still have it or has it fallen inside th trim?
Usually fits over a microswitch. I take it that the switch is still there.
T
TONY PRESCOTT
MANCHESTER
CLK 09 30
Yes must have fallen off but yes the switch is still there.
Problem is cant use memory not major problem but annoying!
Miffy
Bromley, London
If the switch is still there. Shouldnt it still operate ? How about a pic or two to show exactly what you can see ?
Sent from my GT-I9300 using Tapatalk 2
T
TONY PRESCOTT
MANCHESTER
CLK 09 30
Mark
the switch is still there its the cover that moves position to 1 2 3?
Bit dark for a pic soz
There are no separate parts for door switches
m.mycat
T
TONY PRESCOTT
MANCHESTER
CLK 09 30
The picture shows it were number 70 is thats the unit. i want the switch or knob or buttun thats turns the setting to 1 2 3. Any ideas please? Does this just slip on?
No parts at all only the complete unit,,,, what type of shaft is there now it does need a picture to see if something else could be fitted, could the old one be under seat
T
TONY PRESCOTT
MANCHESTER
CLK 09 30
Ive looked evrywere so annoying yet not really needed xcept when wife drives. i'll get a pic tomorrow. thanx for your help. Mercedes suggested test drive 1 sumwere else and nick it ha ha
If you have 2 keys, you can set up one for her and the other for you, this way the knob is not needed
whitenemesis
CLS55 AMG '05
Have you tried breakers? Do you have one on the passenger side you could "borrow" until you find a replacement?
T
TONY PRESCOTT
MANCHESTER
CLK 09 30
  • #18
o rite i have 2 keys so if i use the other key are you saying that will have a different setting? so if i moved seat to a position and removed key wud that position stay?
No breaker will just sell the knob, it will render their switch useless
T
TONY PRESCOTT
MANCHESTER
CLK 09 30
  • #20
Breakers want 2 sell full unit. Passenger door doesnt have memory setting!!!!!
