Hi all, i am trying to remove the interior door panel from my w115 mercedes, but i cant remove the three items in the picture, can someone please help me
Very easy once you know how. For the door opening handle, a small screwdriver between the black plastic insert and the chrome on the left side (I think. Might be the right. The more I think about it the more I suspect it's the right. Been a few years since ...) and you can pop it out of its clips and slide it off the handle. You then find the screw holding the handle.The circular wheel I haven't encountered before but assume it's the quarterlight opener. Almost certainly you pop out the centre chrome circle in a similar fashion and find a centre screw. For the grab handle push the chrome metal end trim up in the direction of the centre of the quaterlight wheel and it will unclip and slide down the handle, exposing the screw. Same at lower end of the grab handle except you push down to unclip and slide up.
Had a 115 in the tropics some years ago, so did this in the warm. Hope you have a good heater in this weather!
