Door trim removal
Status
Not open for further replies.
DrNick1
Registered
I want to remove the door pockets on my 99 E class in order to fit speakers. Does anyone know if the door pockets can be removed without taking the whole door trim panel off? If so, how.
If not, does anyone know how to get the trim panel off without destroying it? Thought it best to ask first before I try - there is always a hidden screw somewhere!
TIA
guydewdney
Tring, Herts
www.atct.co.uk
i have had a look at the epc
the pocket is hed to the door trim with 11 screws, accessed from the back of the main door panel.
the door panel is held on with a few screws - to give you an idea, my 140 coupe is heldf with:-
several screws holding chrome trim on edge of door by door lock - 3 on top half, 5 ish on bottom half
remove cover behind mirror - pops off from top
remove SRS badge in door panel, large phillips behind it
remove small cover in door handle, large vertical screw
small cover under (50p size) handle, large screw behind.
rest of panel just pops off - get a few replacement clips - part number a 006 988 43 78 - v cheap - get half a dozen.
speaker is bolted to the door panel itself - not the cover - nor do you need to remove the pocket....
good luck patience is the key, and not too much force!
guy
Status
