DPf and DPS.
GreenMachine86
VITO c120cdi sportx
Anybody point me in the right location for the DPS sensor on a Vito 120cdi V6.
I recently bought it and it's now trowing the code p2455 it's in limp mode and I tried resetting the codes engine light goes out but limp mode remains. Eg. Lack of power won't shift through gears properly.
I use the van daily so desperate to sort it out.
Thanks in advance
G
GreenMachine86
VITO c120cdi sportx
  • #2
Thanks in advance
Sorry I meant to put this in the exhaust thread but clicked wrong one
G
GreenMachine86
VITO c120cdi sportx
My van is stuck in limp mode with the codes for the DPS sensor. I am guessing the DPf filter is blocked up or would the sensor have gone bad?
Van is a 2010 Vito 120cdi V6.
Anybody have any experience with this van or similar issues. If so how did they fix the issue.
M80
Derbyshire
Depending on the Vito's age the pressure sensor might be mounted underside toward the front of the DPF and o/s. There are 2 pressure feeds off the DPF to it.
G
GreenMachine86
VITO c120cdi sportx
I am going to get under it after work tomoz can I clean the sensor itself and see if that does the trick or just replace it. Or is the DPF being blocked causing the sensor to read high.
