larry1985
- Sep 5, 2021
- c250
Hi all
Apologies if this is in the wrong place, but here goes.
W204 om651 2010 c250
Had some fault codes recently, MB specialist said dpf sensor needed replacing, paid 218 for it and a diagnostic check. Same day, another codes in there, soot level not ok etc etc. Turns out intake mani needs replacing and bolt seized in gasket. 995 later new mani is on.
Same code comes on p2463 I believe, soot level not ok....
Checked data, 400% full, 17.8g soot 0.9g Ash. Today the car wouldn't regen whilst going 80 at 2500rpms.
Do those stats suggest the dpf needs replacing or does it just need forced regen? Have no power at all and should be 248bhp stage 1 remap and 550 lbs of torque, I don't want to spend much more as its starting to sting :,(
