Dpf Removal CLK270
Turns
Cheltenham
clk/2002/270
My dpf is blocked, can anyone recommend where I can get a replacement pipe instead of fitting new unit. Based in gloucestershire
Alex Crow
Super Suffolk
If this is a 2002 CLK270 you do not have a DPF.
Possibly you have a blocked cat, these can be removed from their silencers to good effect.
T
Turns
Cheltenham
clk/2002/270
Hi Alex, thanks for the reply. I had my mechanic look at the car earlier and he has confirmed that it is fitted with the dpf?
Roxie
Lincolnshire
C Class 350CDI 2012
If you have a dpf and remove it you will also have to have the ecu re programmed to prevent limp mode.
Alex Crow
Super Suffolk
Still no DPF on a UK 2002 CLK270 cdi, unless it is some bizzare retrofit or obscure import.
If you have the original service book have a look at the data card in the back, if it has a DPF it will have code 474.
But it wont.
