DREAMER NO2
- Dec 29, 2013
- Age
- 79
- Location
- Kidderminster in Worcestershire
- W124 2.6E M103 1989
Any one done this,, it is possible . I do know that you can use the auxiliary coolant pump ,,by removimg the plug from the rear and then put a 12volt feed to it , to get auxiliary pump to work ..The engine will not be needed to do this operation ...just N + P wire from your battery to auxiliary coolant puimp . So the A/pump will suck out the old coolant but it must have an outlet for the old coolant to escape This is were i am stuck ---so what must be dissconected to let the old coolant escape ? I need the information so i can do this myself. I want to remove all of the old colant,, so i can refill 50/50 . My block tap is stuck and untill i get the manifolds off i cant fix it . Thanks for looking in .
