drain holes in a A class sunroof
Status
Not open for further replies.
brivic17
barrow
Does anyone know how many drain holes there are in a A class sunroof.I have found two at the front but i`m unsure if there are any at the back, and if so how do you get to them. :cry:
landover
Banned
Scotland
www.landrovertd.com
Don't know why you want the rear drain holes. But if you want to get to them you will have to remove the sunroof. :wink:
B
brivic17
barrow
I just thought the ones at the back may be blocked so water was getting over the top then down the back sum how.
B
brivic17
barrow
landover said:
Do you have water in boot? If so check rear window washer pipe this is a common fault.
yes i have quite a bit in the boot.
Status
