You have to take the door card off to fit them,,if you get stuck please ask.
The grill is pushed into the door card through the peg holes, once in the back side of the pin was melted over with a soldering iron,,on could use a good glue.
To get the broken pins out push them through from the front.
You can of coarse just push the broken pins through and leave them in the bottom of the door and use glue on the new one on the pins
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
