Drivers door won’t lock with key or with door switch.
markg14
Essex
C-Class Sport C220 CDI 2007
All door locks behaving normally except drivers door.
Drivers door won’t lock with key, or with switch on drivers door.
Alarm goes off when I open the drivers door, which suggests that the car thinks all doors are locked.
I suspect the drivers door lock mechanism is kaput and needs renewing, but my local independent insists on charging me £125 for diagnosis.
As it is only one door affected, I can’t see it being a defective control unit, but wondered if any other member had a similar problem.
Paying £125 for something I am pretty sure of leaves a bad taste!
axelcls
Kettering
Mercedes w218 CLS63 AMG now gone, RR Velar
Better invest £125 in a iCarsoft
EmilysDad
Bury Lancs
ML350
I've just tried my 14 plate ML .... the locking works as it should via the fob, but the alarm still goes off if I unlock just the driver's door with the emergency blade.
could it just be lack of lubrication in the door locking/opening ,mechanism??
markg14
markg14
Essex
Wasn’t aware the door locks needed lubrication.
Would a squirt of WD40 do any harm?
markg14
markg14
Essex
The drivers door locks and unlocks ok manually, using just the key.
But dead as a dodo to any remote attempts, with either key.
Could be broken wires in the door hinge then
