Drivers window stuck down. M series.
Status
Not open for further replies.
steved
GrandRapids MI USA
greenridge.com
'99 ML320. When I bought it a month ago I noticed at times it would stick going up.
Now today my wife came home with it stuck all the way down.
I hear a faint click when i try to raise or push the switch to lower.
It has a side airbag so I dont want to tear apart until I get advice. I can find no Haynes or Clymers on the M Series.
I have been reading that this is a common problem on owner feedback forum's (car review) , but owners don't say what it took to fix.
piestore
manchester
ml window
hi
Yes it is a very common fault it is normally the window switch, this is very easy to change but the switch is quite expensive
steved
GrandRapids MI USA
greenridge.com
thank you for the reply.
Small world. I just found out a guy in my office had one Fixed under warranty. It was the switch.
_____________________________________________________________
steved
GrandRapids MI USA
greenridge.com
ML320 WINDOW FIX
a guy in my office that experienced the same thing ..It was his switch and speaking to the dealer makes me think 90 percent chance it is the window switch. I understand all the switches are on one board. I Ordered one for $50. Online. The Dealer said $120 install. 5 minute job if you know what you're doing. But I have never done one. I will update this to let M series owners know if it is fixed. AND how to install it, I hope.
July 18th Update. I fixed it. To Replace a window/mirror switch pad.
1) pry loose the trim piece around shift lever.
2) Move shift lever out of Park to gain working room.
3) Pry off the carbon fiber trim/frame piece and the control pod will come with it. 4 screws and 4 clips will remove switch.
I paid $50 for the "Superceded" new switch on line.
Status
