Drivers Window
Andrew Rymer
Cheshire
Hi all,
Can anyone shed any light on this little niggle? When I click the window button to automatically put the drivers side window up it sometimes gets to about halfway up, stops, moves down an inch then parks. I then have to keep my finger on the button to close it fully. Also when i exit the car and lock it, sometimes if I keep my finger pressed on the lock button, it will close the window. My question is why is it only sometimes for both actions?
Regards
Andrew
The window runners could be too tight, lubricate with silicon spray, does not hurt the paint or trim. if the runners are too tight,the window thinks that some ones head is stuck in it,and so it drops again
If the above fails then re set them by holding the switch up for 10 sec once the window has closed in key 2
Andrew Rymer
Andrew Rymer
Cheshire
Thanks Malcolm,
Funnilly enough the window does squeak sometimes! Will do that tomorrow.
Cheers
Andrew
Andrew Rymer
Andrew Rymer
Cheshire
By the way Malcolm, thank you for your wisdom, I think you are a ****** genius!
Regards
Andrew
Thanks Malcolm,
Cheers
Andrew
Anything to make you fall in love with your car again ;);)
Andrew Rymer
Andrew Rymer
Cheshire
If I can get it fixed it will be one of the best cars I have ever had. Mind you I did love the xj8 but it was just a bit to "old image" for me apparently!
Regards
Andrew
SQ_W211
W219 CLS55 AMG
Malc how can i lubricate the rails??? is it by putting the windows all the way down and then spray on each end and then puting them back up?? also i have to hold the lock button about 3 - 4 times before it start to shut the windows... what can be the cause of this?
Andrew Rymer
Andrew Rymer
Cheshire
I can answer that one Amo, yes windows all the way down and spray silicone into channels. I have to keep my button pressed constantly and as soon as I release it the window stops.
Cheers
Andrew
If you are using the key you have to be right in line with the remote and 12" away max. its only when the window is tight that it goes so far and then back down.
Yes as you say is the way to lubricate it, and liftig the window up and down at the same time
SQ_W211
W219 CLS55 AMG
Electric windows button on mine works fine as once clicked it does close the window all the way but when i press the lock button on remote it doesnt always close the windows as i have to press and hold about 3 - 4 times for it to work.
I will try what Malc has suggested and see if that fixes the issue if not it cant cause any harm and lubricating rails can only be good for long term
SQ_W211
W219 CLS55 AMG
Thanks Malc
SQ_W211
W219 CLS55 AMG
ermmm thanks, they are replicas and only cost me £600 for 18" with tyres.
I just keep them clean so they dont flake away as they are known for due to the cheap build
Andrew Rymer
Andrew Rymer
Cheshire
Think I might look at some for mine (if it gets fixed!)....they certainly give it the sporty look.
Regards
Andrew
SQ_W211
W219 CLS55 AMG
let me know if you are interested, i know someone who can sort you out a good deal
