Driveshaft or something else icing up?
occurs_to_me
N Ireland
1976 W114 250 Manual, 2009 W212 E220 CDI Auto
Not sure where to post this, as it’s a bit of an oddity.
2009 E220 diesel auto, had been lying up for about 3 weeks.
About 5 days into the cold snap, (below -1 consistently for 5 days), I decided to turn the car over to check the battery was ok.
It fired up straight away, but there was a small thud, and then considerable vibrations / thumping coming from underneath, in neutral.
I drove about 20” forward - vibrations gone.
Reversed back 20” - vibrations were worse.
So I just parked it up until temperatures were back above 0.
Started it yesterday, took it for a drive and normal service has resumed.
Only thing I can think of is that a block of ice had formed around the driveshaft (or somewhere else), but not sure how or why.
Any other explanations?
Won't be a driveshaft as they only rotate during forward or reverse motion.
O
occurs_to_me
N Ireland
Yeah, that had crossed my mind.
Just reading other posts now, I’m wondering if a frozen shut egr valve would give same symptoms. No lights came on dash though.
ajlsl600
france
Vib damper?
O
occurs_to_me
N Ireland
Vib damper?
Im not sure. I don’t know what that is
Ok, the name gives it away a bit, but where is this located?
O
occurs_to_me
N Ireland
Vib damper?
Ahh, if you mean gearbox or engine mount, that’s what I thought at first. But now that the temperature is higher, and normal service has resumed, I’m kinda ruling those out.
Engine mounts/gearbox mounts. Their behaviour changes with temperature quite dramatically.
Good call. I noticed a shudder on start up at -6 the other morning . Totally gone now .
Mounts we’re all changed a couple of years ago .
O
occurs_to_me
N Ireland
Thanks for that bit of info.
I did have a gearbox mount changed during the summer, just because the Indy I was using (for something unrelated) suggested it. He said the old mount hadn’t failed or anything and a new one wasn’t required, but it would make a difference to driving (comfort?), can’t really remember .
As far as I know, I’m on original mounts for the rest.
Might be something for me to look into in more detail.
Have 100k on the clock. Is there a rule of thumb when they should be replaced, or is it just when noticeable vibrations appear?
mioba
Nottingham and Köln
Mounts need changing when like all damping components. No interval.
As to the OP - could well just be a bit of rust on the pads causing pad stick. Nothing to worry about if so.
A.J.
Norwich. UK
As mioba my first thought was a bit of rust on on the brake disc's. I've had that before after washing the wheels :rolleyes:
