Drop Link Renewal
87henderson
Glasgow, Scotland
Mercedes C180 Kompressor
Hi guys...
Time for another one of my simple questions... :p
To replace the drop link on either side, do i need any special tools?
Scott
Cole@MBS
www.mbssouthampton.co.uk
Very simple, just a 16mm or 17mm spanner for the top and bottom nuts and a 6mm to hold the inner part of the joint......
grober
Scotland
W204 C200cdi estate
Might be worth giving the nuts a bit of spray with plus gas or other releasing agent a couple of days before you tackle them
SteveX
As mentioned on most cars it is very simple, just use a second jack on the bottom of the wishbone (while the car is already in the air on the jack and supported with an axel stand) in a safe place to jack it up a little and take pressure off of the ARB.
Not sure what the set up is on your car, but normally just a nut and bolt at the top on the back of the strut and at the bottom of the rollbar attached to the ARB.
That said, the longest one I changed was on my Porsche, the top bolt of the drop link is about six inches long and doubles as a pinch bolt on the strut to keep the shocker in. It was so seeized that 8 hours later of tapping, heating, banging and screwing, I just decided to cut the damn thing off and welly it through!
87henderson
87henderson
Glasgow, Scotland
Ive got the blow torch on stand by, i jus wasnt sure if there was a special tool needed to hold the inner part.
Thanks again guys
www.W140.co.uk&www.r129.co
