Drop links Anti Roll Bar Bushes.
Frontstep
T210 320cdi
Have completed a grand total of 9000 miles since they were replaced with MB ones and it sounds like there knocking again.
Anyone one else had to replace so quickly ?
All I can say is the quality of these things is awful, OK it may not be that but though the MB links and bushes are cheap to buy, they still have to be fitted.
The drop links for my V70R cost £65 each but they will last for 200k miles
F
Frontstep
T210 320cdi
Had it on a ramp can't really see it being anything else, but looked at everything else first so I will get another set !!!!!!!!!!
taffbrake@hotmail.com
lisburn ni
190e2lt 190e2.6 c220 c220cdi202 c220cd203 w211
If there is a knocking from the drop-link area? check the knuckle that they fit to on the lower wishbone, thats where the knock comes from, it's very rarely its the drop-link itself
whats to wear on the d/link? have you seen the size of the rubber bush its hugh.
this post applies to a w211,you haven,t mentioned yours.
F
Frontstep
T210 320cdi
Mines a 210
tjamesbo
Sutton Coldfield, West Midlands
1999 CLK430, 2007 VITO 3.0V6 , W124's (1994 320TE , 1993 220TE ) , 07 2.5 X-Type
Mine were done at 112K when I got the car . I'm at 148K now and they are still OK on the basis of what I've heard 2yrs is not unusual 9K cant be right tho :confused:
SteveX
Never heard of a set go that quickly but it is possible I suppose.
Turn the steering lay down and if possible grab a fistfull of drop link and try to shake it, if it's that worn you should feel the movement / clonking.
Also how are the ARB bushes looking? Perhaps check the ball joints on the arms too.
From experience drop links rattle and clonk like crazy when going over rough surfaces at low speed like a poorly surfaced car park and when going over bumps in the road (regardless of speed).
ARB bushes normally knock under acceleration and braking.
Ball joints on the ARM are more noticeable at low speed poorly surfaced roads and can be felt more on the steering, whereas the drop links will never shut up.
If you know all of this already sorry - just bored and replying to some threads with hopefully helpful information for people :)
kth286
E320 Coupe 95
I wonder if everything was tightened to correct torque.
It is normally quite low torque.
paulfoel
Just bought a 2nd hand A class with 59K. Noticed from reciepts provided that they've been changed twice in last 10K and they've gone again.
Can't be right surely. I dont think genuine merc ones used but still...
I do not think it can be right
F
Frontstep
T210 320cdi
I don't rate the MB ones mine need replacing again after little mileage.
I might try some FEBI ones next.
y13pmc
doncaster
e320 04
yeh just had mine done they were bad so put aftermarket ones on bit cheaper
pete
paulfoel
Worryingly, seemed ok for 1/2 day but rattling again now. :-(
Is there anything else that can cause these to go wrong?
BAZZER1
FERNDOWN DORSET
E320cdi AVANTGARDE SELECT
Agree with Malcolm, this surely can't be right, there must be something else causing them to have to be replaced so quickly
BAZZER1
paulfoel
I'm beginning to wonder whether rattle is, in fact, something else.
And that my mechanic and previous ones have changed the drop links because this is the most likely cause.
y13pmc
doncaster
e320 04
the rattle on mine looking at my invoice says top ball joint and thrust arm .
thrust arm was bad ball joint replaced as precaution
pete
