e 300td alternator help
ebony266
manchester
E300 W210
hi guys got to remove the alternator on my 96 e300td anyone done this any help well receved thanks :)
Can we ask why you are removing it
ebony266
ebony266
manchester
E300 W210
yes bat drain light on had the alternator checked out only pumping out 15 amps
230K
Belfast
E300TD/1998/3.0 Diesel
To replace the alternator :
Put car up on ramps at the front
Remove front accoustic shield 8mm socket 8no.
Remove middle section accoustic shield 8mm socket 4no.
Undo nut from tensioner 13mm
Take weight of tensioner with ext bar and withdraw the bolt to undo tension on belt.
From underneath remove alloy pipe that runs from turbo to intercooler (2 jubilee clips & 2no 10mm bolts)
Disconnect Battery (Be careful with radio code)
Pull off sleeve on heavy wire to back of alternator
Undo heavy wire 13mm
Undo light wire 11mm
There are 2 bolts holding alternator to engine i used hexagonal socket to fit the splined head on these bolts (cant remember size)
Withdraw bolts and remove alternator via the underside of car.
Reverse sequence for installation.
NB Charge pipe needs removed to get alternator off car.
Are you sure it is not the free wheeling pulley on the alternator slipping causing it to produce a low charge??
Good Luck
230K
ebony266
ebony266
manchester
E300 W210
thanks for your advice never removed one off a mercedes . only played with landrovers give it a go on friday . thanks again !!!
ebony266
ebony266
manchester
E300 W210
thanks again 230k sorry if i seam thick not been under car yo do the alternator yet where is the tensioner nut located ????
230K
Belfast
Top of the tensioner spring.
230k
