E 320 1994 Fluctating RPM at idle and 2500 RPM
Pete1
I have 1994 E 320 MB with 105K. The RPM at idle and park fluctuates some time. This reulted in emission test failure as the test results could not be taken/invalid.
1. What could cause the RPM fluctuations?
2. What do I need to do to correct this?
3. I am also getting a check engine light. How do I read the codes?
I have already changed the air filter, engine oil and oil filter, and cleaned throttle plate with throttle plate cleaner.
I need help!
Pete
Pete,, take out the OVP relay and bridge terminals 30 to 97 and see if its OK
P
Pete1
Thanks Malcolm.
You will have to tell me what an OVP relay is and where will I find it. also where are the terminals 30 and 97 in 1994 E 320 so that I can bridge them.
Pete
kth286
E320 Coupe 95
Pete 1
You say the check engine light is coming on. WHICH light is that exactly as there is NO check engine light on that generation of E320 1994.
Tel: 020 8863 9233
