E class 1996-7 W211 E230 ABS advice requested
Status
Not open for further replies.
georigg
Peterhead, Scotland
Since replacing the rear wheel ring on the half-shaft(which caused the ABS/TCS light to come on etc), I have found that the ABS system is now operating as the car slows down to almost a halt under normal braking(you feel the back-kick on the brake pedal and hear the ABS system operating).
Seems the ABS system has become "sensitive" and is operating even under normal braking as you come to a halt.
Is there a re-set procedure for the ABS system? or any advice please on potential cause.
Ssyetm was working fine before the problem with the half-shaft pick-up ring.
Rgds
Georigg
Arnie
London
Probably your rear sensor is not properly aligned to pick-up all the gear pulses and therefore it is registering a different (slower) speed to your front wheels, hence ABS operating on the rear.
Status
