c270 cdi
Hi all, got this W207 E400 convertible and can't get the airscarf working. I've read lots of other people's threads and posts but they all refer to a fault that the switch lights come on and then go off again. Mine doesn't, the switch lights up (both sides) and stays on, so that would lead me to think the system is working - but no air coming out of the seat.
The heated seats work fine, again both sides, so I'm a bit confused as to how it could be failing if the lights are on.
I've checked all the fuses and they're good, but of note the start/stop isn't functioning which I'm putting down to a poorly battery - charging at 14.7 when running but down to 12.2 at standstill (engine off, all lights off etc) - I've read that battery voltage can affect airscarf but surely if it's getting 14.7 volts when running that should be fine?
I just want to get it going and working properly.
Thanks.
Thanks.
