I don't have any W210 bits (yet) but if it's like the W124 there is a coiled spring at each end for each pull-out bit (luggage retainer & loadspace cover)
It's easy enough to get one end coiled & clipped in place but I couldn't figure out a way of doing both ends - there must be a technique to it!
The pivot bar that runs through the middle is round with flats on it - like a D section - and the flats engage with the plastic end caps. The end cap has a metal clip to keep it all together. I suspect the clip's come adrift and the plastic bit has broken. It's repairable, in theory, but I've not managed it. Maybe someone else has?
Sorry for the late reply, the luggage cover is in "as new" condition as it has received very little use. Retail from the dealers is well over £500, (just checked and nearly had a heart attack). I am looking for about £100.
