E class P0237 code
Dale Phillips
E class w212
P0237 turbo pressure sensor replaced two and it’s made the car worse won’t let me rev above 3000rpm anyone free to help me
Oldspanners
Normandy
C CLASS 2004 C180
Not an expert in these matters, I'm sure one will be along shortly.
P0237 Turbo/Super Charger Boost Sensor “A” Circuit Low
Seems like your car is in limp mode, have you reset the code after changing the part and read the codes again?
Check the wiring to the sensor as well, if you have a wiring diagram check the conditions at the connector.
D
Dale Phillips
E class w212
Yeah I’ve cleared the codes but still won’t let me rev above 3000rpm
