E-Class w211 drivers door card
C
CABBIE 114
Hi can anyone help me with the removal of my drivers door card as i have a prob. with my central lock on that door :( Thanks
Ellsy Tanners
Mars
C
CABBIE 114
w211 door card
thanks for your help and yes lock is jumping is this easy to install
If the button is jumping then you need a new lock, as there is a broken spring inside
124coupe
Its worth grabbing a trim removal tool (halfords v cheap) to avoid snapping the poppers as you remove them. The tool has a fork one end and a blade the other and is great for all trim jobs (its stiff plastic so doesn't scratch).
Ellsy Tanners
Mars
On most models you have to partially remove the electric window regulator, by drilling out the riviots that hold it in place, detaching it from the glass and moving aside, so you have room to remove the lock from inside the door.
the airbag will also have to be removed if i remember correctly.
Make sure you order some correct riviots with a new lock.
The best thing is that they do not tear the door cards
C
CABBIE 114
w211 door card
many thanks for your help it sounds as if it is a tad difficult think i will have to put it in to the main dealer in Aberdeen to do the lock
many thanks
Gary22
New Registration
hi does anyone have the instructions on how to remove the window regulator step by step, do i have to take out the motor,
Dec
Ireland.
W202
Depends what car? What year? And if its for front or back Gary.
Dec
aultonater
Nottingham
E-Class '53 plate Estate E270cdi avantgarde
Hi Guys, I'm new to Mercedes ownership and new to the forum.
Looking for any help guidence as I have developed the bouncing door lock on the drivers door of my 53 plate W211 estate
Looks like I need to remove door card and replace the lock, after reading this thread, so directions on both would be great thanks.
Chris
Developer
S212 E63 S 5.5 biturbo
If you email me I'll send you what was sent to me when I asked. When the instruction says about removing the door lock you have to pull off the door seal and put a torx driver through the hole underneath.
