E200 cruise control
There is a lot to these systems, a bad hall sensor in the cluster or an amp fault,,,as soon as I get a minute I will check the list
jimsinessex
Essex
2008 W209 CLK 320CDI Coupe
Could be the brake light switch, this has multiple contacts and the cruise control bit can fail without affecting the brake lights.
A new switch is cheap and easy to change, cheaper even than having the codes read which is the other way to pinpoint the problem.
Jim
www.W140.co.uk&www.r129.co
