E200 Key/Remote
templeman
My keyfob/remote has packed in on my 1995/96 E200 Elegance, can anyone suggest what I should do to fix or replace this please?
Hello and welcome, got to the DIY section, Anyweb has done a very good article
With a digital camera you can see if it works
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Mine failed, turned out to be the micro switch below the press button, its soldered in four places, I think dropping it gave it the chance to break free, resoldered the switch back on and its been great since. Olso the metal clip that holds the batteries in place snapped so I have some foil in its place seems to work.
jib
BlackC55
South coast
C43
Its a differeent key to that one Malcom.
Take the key apart and seeif there is anything loose inside.
Other than than its dealer only
T
templeman
Thanks for the posts guys, took the thing apart- messy business as it was superglued, and re-soldered the switch which had come off, working now, much thanks to niall brady http://www.niallbrady.com/mycar/c220/ whose info was invaluable.
You have saved £150 on the cost of buying a new one :D thanks for posting back
