e200 w124 catalytic converter
ravs
i need to change the catalytic of my car i was quoted £1100.00,has anyone encountered this problem and can anyone suggest me about aftermarket cats please thanks
silverhorse
Blackpool UK
300E/1998/3000diesel
I recently had a new cat . cost £750 on E 300 1998, Ask for credit on the scrap though . I did not and found out they could be worth upm to £200. See other thread about scrap cats.
d215yq
Valencia, Spain
1987 W124 300D 280k miles
You can buy generic catalysts on ebay based on engine size which can often be fitted to cars with minimal modification to the other exhaust pipes and cost < £100 new.
Guess it won't be original manufacturers spec and haven't any experience with this on Mercs but did it on my old rover and it worked perfectly, no rattles and passed the emissions test. Might be worth it, particularly if car isnt worth a great deal.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Problem is some of these non genuine cats only work if they are really hot and can fail the MOT because they dont get hot enough on tick over before the MOT.
jib
kth286
E320 Coupe 95
ravs
before you condem the cat get the lambda probe (oxygen sensor tested/replaced as that is the real component that stops excess fuelling of the engine.
for a properly tuned engine you could leave the cat off and still pass the emissions test (as some people indeed do).
