Glenn0166
New Registration
- Oct 6, 2020
- 2009 c220 cdi
Old thread BUT I am sure people still search these!
P2463 code on a cheap obd2 scanner.. DTC definitions not found.
DPF sensor fail in my instance .. which I changed..
BUT be aware you need to reset the DPF level under the 130% value and force the computer to reset it self via a regen.
I learnt this after trying to reset codes. Codes would reset BUT not fix the issue.
You need a "smart" OBD2 reader to complete the process. Just my 2 cents worth.. hope it helps
