E220 Boot spring Adjustments
makem73
E220 Cabriolet 2015
Hi my E220 Cabriolet boot used to auto lift but doesn't now. How do I adjust the boot lid springs?
Help.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
You haven’t added something to it like a spoiler, for example. Extra weight can sometimes mess up the fine balance of the springs.
M
makem73
E220 Cabriolet 2015
No additions. I’ve read you can adjust the tension on the boot springs but no advice how to increase the tension.
mioba
Nottingham and Köln
Do not adjust the tension until you have cleaned and lubed the hinges
M
makem73
E220 Cabriolet 2015
Cleaned and lubricated hinges already just need to find out how to adjust the spring tension.
DREAMER NO2
W124 2.6E M103 1989
Get in to the boot with a pice of strong cord , and put a loop over existing spring hook , will help if someone closed the boot a little at the same time .Then pull on it and use another hole in the bracket to tension the spring .If no extra holes then you will need a new spring .
M
makem73
E220 Cabriolet 2015
DREAMER NO2
W124 2.6E M103 1989
You are right,, i have never seen those before,, but there again you never did said the post listing what model they were for .
M
makem73
E220 Cabriolet 2015
Makem you need to fill in your profile so members know what car you have
Yes I will ...being a new member I’m feeling my way around.
By the way it’s a 2015 E220 Cabriolet.
DREAMER NO2
W124 2.6E M103 1989
Thats why i knew nothing about the spring after seeing the picture . But Welcome to the forum . Just keep looking in some one will came back to you soon ..
M
makem73
E220 Cabriolet 2015
Thanks for your help.
I’ll update my info today
