E220 cdi A207 Headlight change for Europe
Carvalho
Mercedes E 220 Cdi A207 convertible 2014 Diesel
Hi I’m new to this
I have a mercedes E220 cdi A207 diesel convertible 2014 I’m going to work in Portugal and I like to know if the headlights have any way to change the beam from Right to Left Hand
Many thanks
C
Carvalho
  • #2
I have à Mercedes E220 cdi A 207 2014 convertible I’m going to work in Portugal and if possible to change the headlights beam from Right to Left is there any way
Kind regards
Hello and welcome,
I've merged your posts and move them to the correct forum.
Hi I’m new to this
Many thanks
Is there not a lever inside the headlamp to cut off the upsweep to the left of the RHD lamp? Or depending on the type of lamp .... my 14 plate ML with its ILS lights can be switched via the dash cluster
Sleeper
Southend on Sea
R172 SLK200 AMG / C253 GLC Coupe / W166 ML 250 AMG / W213 E Class / W212 E Class
If you have the Mercedes intelligent light system its fairly easy to change on the dashboard controls, if you don't have intelligent light system then I would just fit headlight deflectors to you headlights.
RTFM or get new headlamps.
Apologies if I offended anyone. The information will be in the users manual - there is always a section for adjusting the headlamps for driving abroad.
If you intend on keeping the car in Portugal you may want to replace the headlamps for the long term as this "may" help you getting through the MOT equivalent.
C
Carvalho
I will try to find if there is a lever inside the headlights near the main lamp
I can’t see Mercedes making 2 kind of headlights one for Uk and other for EU
Many thanks all the info is great appreciated
Can’t fit deflectors if moving over there for extended period of time as won’t pass local tests
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Oh yes they would. The UK is not the only country in the world to drive on the left. All the lever adjustment does is to make the asymmetric headlamps symmetrical by taking the top corner of the right hand side of the beam, it doesn’t make them dip the other way, For that, you need specific left hand drive (right hand traffic)) headlamps.
They can put steering wheels on the other side, entire dash boards, entire displays, car mats being different, wiper blades to name a few
Hell yes they can and do and so does pretty much every car manufacturer.
