dieselman
- Feb 10, 2001
- A diesel
A collegue as an E220 CDi auto. Intermittantly the car doesn't change above 3rd even on a light throttle. As soon as the accelerator is prodded the box will change up to 4th and 5th as normal with no increase in road speed.
Initially a new electronoic plate was fitted in the gearbox and then a new box was fitted. The fault still exists.
His own thoughts are that the throttle pot may be faulty as the box changes normally as soon as the accelerator is moved.
My thoughts lead to the gearbox control ECU, as I believe it was not changed with the gearbox.
There are no fault codes.
Any ideas would be welcomed as three local dealers were sure the new box would fix it.
