darrensbrooks0
- Jun 19, 2008
I have a problem with bolting down the injector to the head on a 1999 E220 Cdi, the problem is that it just won't bolt down tight enought to stop blow back (the puff puff noise and associated puff of smoke). I have used new bolts, washer sills, injector bracket and have cleaned everything up as much as possible but to no avail, it still does it, a experienced mechanic friend has also tried the same as I have but no luck. It has come to the point where we think the treads in the head are damaged though I loathe to take the head off and get it machined for such a minor problem (though I realise that the problem will only get worse, it's why the injector was removed in the first place!). Does anyone know any way around this? Will hellicoil treads work? Or is this a common problem? Any info would be fantastic as I'm really pulling my hair out and my boss is starting to moan about me using the company van!
