Gyri
My 1996 Petrol E220 W124 (HFM type) engine (111.960) every now and then annoys me while accelerating. This happens once in maybe 3 KM of running, with or without the aircon ON. When it happens, it basically for a second doesn't respond to the accelerator input and then lunges forward jerking-ly. I have found that when it happens, I can get over it by depressing the clutch pedal and then pumping the gas pedal fully a couple of times. It then resumes to running normally, until maybe a few KM later. This can happen during gear shifts or while giving throttle inputs from steady speeds.
OK, the story before this is that the car used to stall much like W124 s described in many other threads. I had MB authorised men have a look at it with their diagnostic tools, all in all they had my car for a month and a half.
First it was the Engine wiring harness which was re-insulated by them for almost 1/3rd the cost of a new part. Then all filters (air, fuel, oil) were replaced. Fuel tank cleaned, New throttle cable, new spark plugs, new fuel pump (the old one was whining, but load and delivery test showed it performing well). OVP relay was visually checked and it was the new SIEMENS one, so that was ok. Throttle body was cleaned. The diagnostic kit showed all the sensors to be working fine. Well, the engine doesn't stall anymore and I haven't noticed any abnormal RPM hunting off late, but then every now and then she behaves as though she moves on square boots :roll:
Ran the tank through a can of injector cleaners, No luck!
Naturally, MB gave me a list of components to change, which pretty much excluded only the body panels. It was time for me to take my car and leave.
So here I am.
Any and every bit of help would be very much appreciated!
Thanks in advance!!!!
BTW, my car has run 41000 KM. :evil:
So here I am.
