E220 seat belt problem
I have just bought a 1994 e220 coupe with 42k miles. the passenger self feeding seat belt does not work, do i need a new motor.
Any advice please
Hello and welcome, first thing to check is the light switch switch in the door pillar
I will see what I have this evening
kth286
E320 Coupe 95
Did you check the fuse - they do corrode - turn it in it's holder.
Is there a noise as if it is trying to work ???????
kth286
E320 Coupe 95
In main fusebox in engine compartment.
It may have been disabled as the driver did not like it.
kth286
E320 Coupe 95
Did you differentiate between the two seatbelt fuses OK ?
If not the fuse there is a sensor in the seat base that should prevent the belt extending if no person in seat.
Perhaps that is faulty/disconnected.
Perhaps it is sticking - try and hit the seat base or try and jump up and down in the seat with door open and ignition on.
L
Yes, i changed both fuses. I will try jumping on the seat !!!! hope my wife wont send me away!!!
www.ckinsurance.co.uk
